Zerotier-One Proxmox LXC script
ZeroTier is a secure network overlay that allows you to manage all of your network resources as if they were on the same LAN. The software-defined solution can be deployed in minutes from anywhere. No matter how many devices you need to connect, or where they are in the world, ZeroTier makes global networking simple.
To create a new Proxmox VE Zerotier-One LXC, run the command below in the Proxmox VE Shell.
To Update Zerotier-One, run the command below (or type update) in the LXC Console.
bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/ct/zerotier-one.sh)"
You can use the following credentials to login to the Zerotier-One ct.
Username: admin
Password: password
Default Interface: IP:3443
