Z-Wave JS UI is an open-source software that serves as a gateway between Z-Wave devices and MQTT (Message Queuing Telemetry Transport) protocol, allowing users to control and monitor their Z-Wave devices via a user interface. The software provides a configurable platform to manage Z-Wave networks and integrate with other smart home systems through MQTT.
🛈 If the LXC is created Privileged, the script will automatically set up USB passthrough.
To create a new Proxmox VE Z-Wave JS UI LXC, run the command below in the Proxmox VE Shell.
To Update Z-Wave JS UI, run the command below (or type update) in the LXC Console.
bash -c "$(curl -fsSL https://raw.githubusercontent.com/community-scripts/ProxmoxVE/main/ct/zwave-js-ui.sh)"
Default Settings: 1GB RAM - 4GB Storage - 2vCPU
Z-Wave JS UI Interface: IP:8091
