wger (ˈvɛɡɐ) Workout Manager is a free, open source web application that helps you manage your personal workouts, weight and diet plans and can also be used as a simple gym management utility. It offers a REST API as well, for easy integration with other projects and tools.
To create a new Proxmox VE wger LXC, run the command below in the Proxmox VE Shell.
To Update wger, run the command below (or type update) in the LXC Console.
bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/ct/wger.sh)"
- You can use the following credentials to login to the wger ct.
admin - Password:
adminadmin
HDD: 6GB
