Unmanic is a simple tool for optimising your file library. You can use it to convert your files into a single, uniform format, manage file movements based on timestamps, or execute custom commands against a file based on its file size.
To create a new Proxmox VE Unmanic LXC, run the command below in the Proxmox VE Shell.
To Update Unmanic, run the command below (or type update) in the LXC Console.
bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/ct/unmanic.sh)"
Default Settings: 2GB RAM - 4GB Storage - 2vCPU
Unmanic Interface: IP:8888
