TasmoCompiler is a simple web GUI which allows you to compile fantastic Tasmota firmware with your own settings.
To create a new Proxmox VE TasmoCompiler LXC, run the command below in the Proxmox VE Shell.
To Update TasmoCompiler, run the command below (or type update) in the LXC Console.
bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/ct/tasmocompiler.sh)"
HDD: 10GB
