Stirling-PDF is a powerful locally hosted web based PDF manipulation tool that allows you to perform various operations on PDF files, such as splitting merging, converting, reorganizing, adding images, rotating, compressing, and more.
To create a new Proxmox VE Stirling-PDF LXC, run the command below in the Proxmox VE Shell.
To Update Stirling-PDF, run the command below (or type update) in the LXC Console.
bash -c "$(curl -fsSL https://raw.githubusercontent.com/community-scripts/ProxmoxVE/main/ct/stirling-pdf.sh)"
Stirling-PDF Interface: IP:8080
