Slskd is a modern client-server application for the Soulseek file sharing network.
To create a new Proxmox VE slskd LXC, run the command below in the Proxmox VE Shell.
To Update slskd, run the command below (or type update) in the LXC Console.
bash -c "$(curl -fsSL https://raw.githubusercontent.com/community-scripts/ProxmoxVE/main/ct/slskd.sh)"
- See
/opt/slskd/config/slskd.ymlto add your Soulseek credentials - This LXC includes Soularr; it needs to be configured (
/opt/soularr/config.ini) before it will work - Documentation
- Location of config file:
Default Login Credentials
slskd - Password:
slskd
