To use the PVE Privilege Converter script, run the command below only in the Proxmox VE Shell. This script is intended for managing or enhancing the host system directly.
bash -c "$(curl -fsSL https://raw.githubusercontent.com/community-scripts/ProxmoxVE/main/tools/pve/pve-privilege-converter.sh)"
- Execute this script inside the Proxmox shell as root.
- Ensure that the backup and target storage have enough space.
- The container will be recreated with a new ID and desired privilege setting.
