With PS5-MQTT you can integrate your Sony Playstation 5 devices with Home Assistant using MQTT.
To create a new Proxmox VE PS5-MQTT LXC, run the command below in the Proxmox VE Shell.
To Update PS5-MQTT, run the command below (or type update) in the LXC Console.
bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/ct/ps5-mqtt.sh)"
After installation, the MQTT endpoint must be configured. The configuration file is located within the LXC container at:
/opt/.config/ps5-mqtt/config.json
HDD: 3GB
Default Interface: IP:8645
