This script will add Monitor-All to Proxmox VE, which will monitor the status of all your instances, both containers and virtual machines, excluding templates and user-defined ones, and automatically restart or reset them if they become unresponsive. This is particularly useful if you’re experiencing problems with Home Assistant becoming non-responsive every few days/weeks. Monitor-All also maintains a log of the entire process, which can be helpful for troubleshooting and monitoring purposes.
🛈 Virtual machines without the QEMU guest agent installed must be excluded.
🛈 Prior to generating any new CT/VM not found in this repository, it’s necessary to halt Proxmox VE Monitor-All by running systemctl stop ping-instances.
All commands are run from the Proxmox VE shell..
To add or remove Monitor-All in Proxmox VE:
bash -c "$(wget -qLO - https://github.com/tteck/Proxmox/raw/main/misc/monitor-all.sh)"
To make setup changes, first stop the service: systemctl stop ping-instances
To edit pause time:
nano /usr/local/bin/ping-instances.sh
To add excluded instances:
nano /etc/systemd/system/ping-instances.service
After changes have been saved, systemctl daemon-reload and start the service: systemctl start ping-instances
Monitor-All logs : cat /var/log/ping-instances.log
