A dark theme for the Proxmox VE Web UI is a custom theme created by Weilbyte that changes the look and feel of the Proxmox web-based interface to a dark color scheme. This theme can improve the visual experience and make the interface easier on the eyes, especially when used in low-light environments.
Run the command below in the Proxmox VE Shell.
bash <(curl -s https://raw.githubusercontent.com/Weilbyte/PVEDiscordDark/master/PVEDiscordDark.sh ) install
To uninstall the theme, simply run the script with the uninstall command.
