To use the PVE LXC Tag script, run the command below only in the Proxmox VE Shell. This script is intended for managing or enhancing the host system directly.
bash -c "$(curl -fsSL https://raw.githubusercontent.com/community-scripts/ProxmoxVE/main/tools/pve/add-iptag.sh)"
- Configuration: nano
/opt/iptag/iptag.conf. iptag Service must be restarted after change. - The Proxmox Node must contain ipcalc and net-tools.
apt-get install -y ipcalc net-tools - You can execute the ip tool manually with
iptag-run
IP-Tag Configuration Guide
The IP-Tag script automatically applies IP-based tags to LXC containers and VMs in Proxmox VE. This allows you to quickly identify machines by IP (or partial IP) directly in the Proxmox web UI.
This guide explains:
- What the config values mean
- How to adjust them to lower CPU usage
- How to manually run the script on demand
Configuration File
The config file is located at:
It contains all runtime settings and can be edited at any time. After editing, run:
systemctl restart iptag
to apply the changes.
General Settings
| Variable | Description | Default |
TAG_FORMAT |
Format for tags created from IPs | last_two_octets |
CIDR_LIST |
Allowed IP ranges for tagging (others are ignored) | See below |
LOOP_INTERVAL |
Time (in seconds) between script executions (when running as a service) | 300 |
FORCE_UPDATE_INTERVAL |
Maximum time between forced re-checks (even without changes) | 7200 |
Example: TAG_FORMAT
TAG_FORMAT="full"
- Output format: Full IP address
- Example:
If IP =192.168.1.123β Tag =192.168.1.123
TAG_FORMAT="last_octet"
- Output format: Only the last octet of the IP
- Example:
If IP =192.168.1.123β Tag =123
TAG_FORMAT="last_two_octets"
- Output format: Last two octets of the IP
- Example:
If IP =192.168.1.123β Tag =1.123
Update Intervals
| Variable | What it checks | Default (seconds) |
VM_STATUS_CHECK_INTERVAL |
Checks if VM state changed | 600 |
LXC_STATUS_CHECK_INTERVAL |
Checks if LXC state changed | 300 |
FW_NET_INTERFACE_CHECK_INTERVAL |
Detects bridge/interface changes | 900 |
Performance Tuning
These values control how aggressively and in parallel the script scans containers/VMs. Lower values = lower CPU.
VM Performance
| Variable | Description | Suggested for Homelab |
VM_IP_CACHE_TTL |
How long (in sec) to cache found IPs | 300 |
MAX_PARALLEL_VM_CHECKS |
Max VMs to process in parallel | 2β4 |
LXC Performance
LXC_IP_CACHE_TTL |
Time (in sec) to cache LXC IPs | 300 |
LXC_STATUS_CACHE_TTL |
Cache status (running/stopped) of LXC | 300 |
LXC_BATCH_SIZE |
How many LXCs to process at once in a batch | 3β5 |
MAX_PARALLEL_LXC_CHECKS |
How many containers to check at the same time | 2β3 |
LXC_AGGRESSIVE_CACHING |
Enables smart caching logic | true |
LXC_SKIP_SLOW_METHODS |
Disables pct exec and lxc-attach fallback (less accurate) |
true |
Example: Optimized Config for Homelab
# Use simplified IP format
# Only tag private subnets
CIDR_LIST=(
192.168.0.0/16
10.0.0.0/8
# Lower background frequency
LOOP_INTERVAL=600
FORCE_UPDATE_INTERVAL=7200
# Reduce VM scan load
VM_IP_CACHE_TTL=300
MAX_PARALLEL_VM_CHECKS=2
# Reduce LXC scan load
LXC_IP_CACHE_TTL=300
LXC_STATUS_CACHE_TTL=300
LXC_BATCH_SIZE=3
MAX_PARALLEL_LXC_CHECKS=2
LXC_AGGRESSIVE_CACHING=true
LXC_SKIP_SLOW_METHODS=true
Manual Execution (no systemd required)
If you donβt want to run iptag as a service, you can run it manually at any time:
iptag-run
This command executes the tag update logic once and exits.
It does not stay running in the background.
The script is installed to:
/usr/local/bin/iptag-run
Disabling the Service
To fully disable the background service:
systemctl disable --now iptag
Then use iptag-run whenever you want to apply tags.
Log Output & Debugging
To avoid log spam, the service outputs minimal info. You can enable verbose logs for debugging:
DEBUG=true
Then run manually or restart the service.
Troubleshooting
| Problem | Solution |
| High CPU load | Lower LXC_BATCH_SIZE, MAX_PARALLEL_*, increase TTL values |
| Tags get removed unexpectedly | Check TAG_FORMAT, CIDR_LIST and IP detection logic |
| Systemd restarts the service too often | Ensure loop is internal, not via Restart=always |
