NOT WORKING ON ZFS
A standalone Podman container-based installation of Home Assistant Core means that the Home Assistant Core software is installed inside a container managed by Podman, separate from the host operating system. This provides a flexible and scalable solution for running the software, as the container can be easily moved between host systems or isolated from other processes for security. Podman is a popular open-source tool for managing containers that is similar to Docker, but designed for use on Linux systems without a daemon.
🛈 If the LXC is created Privileged, the script will automatically set up USB passthrough.
To create a new Proxmox VE Podman Home Assistant Container LXC, run the command below in the Proxmox VE Shell.
To Update Podman, Install HACS or FileBrowser, run the command below (or type update) in the LXC Console.
bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/ct/podman-homeassistant.sh)"
Default Settings: 2GB RAM - 16GB Storage - 2vCPU
Home Assistant Interface: IP:8123
Path to HA /config
/var/lib/containers/storage/volumes/hass_config/_data
