phpIPAM Proxmox LXC script
phpipam is an open-source web IP address management application (IPAM). Its goal is to provide light, modern and useful IP address management.
To create a new Proxmox VE phpIPAM LXC, run the command below in the Proxmox VE Shell.
To Update phpIPAM, run the command below (or type update) in the LXC Console.
REMOVED
You can use the following credentials to login to the phpIPAM ct.
Username: Admin
Password: ipamadmin
Default Interface: IP:80
Hello, i want to use this script but the file is not existing on repo GitHub.
I think that the .sh is supress :wink:
It was removed beacause of constant issues with the app itself.
