Pelican Wings is Pelican’s server control plane, built for the rapidly changing gaming industry and designed to be highly performant and secure. Wings provides an HTTP API allowing you to interface directly with running server instances, fetch server logs, generate backups, and control all aspects of the server lifecycle.
To create a new Proxmox VE Pelican Wings LXC, run the command below in the Proxmox VE Shell.
To Update Pelican Wings, run the command below (or type update) in the LXC Console.
bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/ct/pelican-wings.sh)"
- After installation, you need to use the Auto Deploy command generated by Pelican Panel and, after running the command, restart the Wings service with
systemctl restart wings.service
HDD: 8GB
