Paymenter is an open source webshop solution for hosting companies. It’s developed to provide an more easy way to manage your hosting company.
To create a new Proxmox VE Paymenter LXC, run the command below in the Proxmox VE Shell.
To Update Paymenter, run the command below (or type update) in the LXC Console.
bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/ct/paymenter.sh)"
You can use the following credentials to login to the Paymenter ct.
admin@paymenter.org - Password:
paymenter
HDD: 5GB
Default Interface: IP:80
