Paperless-GPT seamlessly pairs with paperless-ngx to generate AI-powered document titles and tags, saving you hours of manual sorting. While other tools may offer AI chat features, paperless-gpt stands out by supercharging OCR with LLMs-ensuring high accuracy, even with tricky scans. If you’re craving next-level text extraction and effortless document organization, this is your solution.
To create a new Proxmox VE Paperless-GPT LXC, run the command below in the Proxmox VE Shell.
To Update Paperless-GPT, run the command below (or type update) in the LXC Console.
bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/ct/paperless-gpt.sh)"
- Configuration File:
/opt/paperless-gpt-data/.env
CPU: 3vCPU
HDD: 7GB
Default Interface: IP:8080
