Outline is the fastest knowledge base for growing teams. Beautiful, realtime collaborative, feature packed, and markdown compatible. It’s time to get your team’s knowledge organized.
To create a new Proxmox VE Outline LXC, run the command below in the Proxmox VE Shell.
To Update Outline, run the command below (or type update) in the LXC Console.
bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/ct/outline.sh)"
After installation finishes, application will do a database migration so web UI might be unavailable for a minute or two. Also you need to manually add authentication and/or enable HTTPS.
Configuration file is at:
/opt/outline/.env. Modify to suit your environment.
HDD: 8GB
