OpenProject is a web-based project management software. Use OpenProject to manage your projects, tasks and goals. Collaborate via work packages and link them to your pull requests on Github. Read more about the OpenProject GitHub integration.
To create a new Proxmox VE OpenProject LXC, run the command below in the Proxmox VE Shell.
To Update OpenProject, run the command below (or type update) in the LXC Console.
bash -c "$(curl -fsSL https://raw.githubusercontent.com/community-scripts/ProxmoxVE/main/ct/openproject.sh)"
Location of config file: /etc/openproject/conf.d/env
You can use the following credentials to login to the OpenProject ct.
admin - Password:
admin
HDD: 8GB
Default Interface: IP:80
