ONLYOFFICE Docs is an open-source online office suite that provides collaborative editors for text documents, spreadsheets, and presentations, fully compatible with Microsoft Office formats (DOCX, XLSX, PPTX).
To create a new Proxmox VE ONLYOFFICE Docs LXC, run the command below in the Proxmox VE Shell.
To Update ONLYOFFICE Docs, run the command below (or type update) in the LXC Console.
bash -c "$(curl -fsSL https://raw.githubusercontent.com/community-scripts/ProxmoxVE/main/ct/onlyoffice.sh)"
Location of config file
/etc/onlyoffice/documentserver/local.json
Database / RabbitMQ Credentials
cat ~/onlyoffice.creds
You can use the following credentials to login to the ONLYOFFICE Docs ct.
admin - Password:
admin
- CPU: 2vCPU
- RAM: 2GB
- HDD: 10GB
- Default Interface:
IP:80
