Odoo is a comprehensive open-source business platform made up of modular apps that cover key areas such as CRM, accounting, inventory, sales, project management, HR, helpdesk, and e-commerce. All modules are tightly integrated, allowing businesses to fully digitize and automate their workflows. Its modular design makes it suitable for both small companies and large enterprises, with flexibility to adapt to different industries. Odoo combines user-friendliness with powerful functionality, offering a unified solution for managing a wide range of business operations.
To create a new Proxmox VE Odoo LXC, run the command below in the Proxmox VE Shell.
To Update Odoo, run the command below (or type update) in the LXC Console.
bash -c "$(curl -fsSL https://raw.githubusercontent.com/community-scripts/ProxmoxVE/main/ct/odoo.sh)"
Database Credentials: cat ~/odoo.creds
Location of config file: /etc/odoo/odoo.conf
You can use the following credentials to login to the Odoo ct.
admin - Password:
admin
HDD: 6GB
Default Interface: IP:8069
