NZBGet is a Usenet downloader focused on efficiency and performance, designed to handle NZB files for downloading content from Usenet. It automates downloading, checking, repairing, and extracting files, optimizing resources to run well on lower-powered devices.
To create a new Proxmox VE NZBGet LXC, run the command below in the Proxmox VE Shell.
To Update NZBGet, run the command below (or type update) in the LXC Console .
bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/ct/nzbget.sh)"
Default Login Credentials
You can use the following credentials to login to the NZBGet ct.
Username: nzbget
Password: tegbzn6789
Default Interface: IP:6789
