Microsoft Activation Scripts (MAS)
A Windows and Office activator using HWID / Ohook / KMS38 / Online KMS activation methods, with a focus on open-source code and fewer antivirus detections.
Features
- HWID (Digital License) Method to Permanently Activate Windows
- Ohook Method to Permanently Activate Office
- KMS38 Method to Activate Windows/Server Till the Year 2038
- Online KMS Method to Activate Windows/Server/Office For 180 Days (Lifetime With Renewal Task)
- Advanced Activation Troubleshooting
- $OEM$ Folders For Preactivation
- Change Windows Edition
- Check Windows/Office Activation Status
- Available in All In One and Separate Files Versions
- Fully Open Source and Based on Batch Scripts
- Fewer Antivirus Detections
Method 1 - PowerShell
(Recommended)
- On Windows 8.1 / 10 / 11, right-click on the Windows start menu and select PowerShell or Terminal (Not CMD).
- Copy and paste the code below and press enter
irm https://massgrave.dev/get | iex
You will see the activation options. Follow the on-screen instructions.
That’s all.
Method 2 - Traditional
Download the file from Github or BitBucket
Right click on the downloaded zip file and extract
In the extracted folder, find the folder named All-In-One-Version
Run the file named MAS_AIO.cmd
You will see the activation options, follow the on-screen instructions.
That’s all.
To run the scripts in unattended mode, check here.
