Meilisearch is a fast, open-source search engine designed for instant, full-text search with typo tolerance. It provides an API that allows developers to integrate powerful search features into applications. Meilisearch-UI is an optional web-based interface that provides a simple way to interact with Meilisearch, visualize indexed data, and test queries without needing to use the API directly.
To create a new Proxmox VE Meilisearch LXC, run the command below in the Proxmox VE Shell.
To Update Meilisearch, run the command below (or type update) in the LXC Console.
bash -c "$(curl -fsSL https://raw.githubusercontent.com/community-scripts/ProxmoxVE/main/ct/meilisearch.sh)"
- Meilisearch-UI can optionally be installed for a web-based search interface
- Meilisearch-UI has early development status and can cause performance issues
- Documentation
- Location of config file
/etc/meilisearch.toml
