Mealie is a self hosted recipe manager, meal planner and shopping list with a RestAPI backend and a reactive frontend built in Vue for a pleasant user experience for the whole family. Easily add recipes into your database by providing the URL and Mealie will automatically import the relevant data, or add a family recipe with the UI editor. Mealie also provides an API for interactions from 3rd party applications.
To create a new Proxmox VE Mealie LXC, run the command below in the Proxmox VE Shell.
To Update Mealie, run the command below (or type update) in the LXC Console.
bash -c "$(curl -fsSL https://raw.githubusercontent.com/community-scripts/ProxmoxVE/main/ct/mealie.sh)"
Location of config file
/opt/mealie/mealie.env
- CPU: 2vCPU
- RAM: 2GB
- HDD: 10GB
- Default Interface:
IP:9000
