Matterbridge allows you to have all your Matter devices up and running in a couple of minutes without having to deal with the pairing process of each single device.
š If the LXC is created Privileged, the script will automatically set up USB passthrough.
To create a new Proxmox VE Matterbridge LXC, run the command below in the Proxmox VE Shell.
To Update Matterbridge, run the command below (or type update) in the LXC Console.
bash -c "$(curl -fsSL https://raw.githubusercontent.com/community-scripts/ProxmoxVE/main/ct/matterbridge.sh)"
Matterbridge Interface: IP:8283
