Librespeed Rust Proxmox LXC script
Librespeed is a no flash, no java, no websocket speedtest server. This community script deploys the rust version for simplicity and low resource usage.
To create a new Proxmox VE Librespeed Rust LXC, run the command below in the Proxmox VE Shell.
To Update Librespeed Rust, run the command below (or type update) in the LXC Console.
bash -c "$(curl -fsSL https://raw.githubusercontent.com/community-scripts/ProxmoxVE/main/ct/librespeed-rust.sh)"
Location of config file
/var/lib/librespeed-rs/configs.toml
  • CPU: 1vCPU
  • RAM: 512MB
  • HDD: 4GB
  • Default Interface: IP:8080
