Graylog Proxmox LXC script
Graylog is a free and open log management platform.
To create a new Proxmox VE Graylog LXC, run the command below in the Proxmox VE Shell.
To Update Graylog, run the command below (or type update) in the LXC Console.
bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/ct/graylog.sh)"
  • Initial Setup credentials: tail /var/log/graylog-server/server.log after the server starts for the first time.
  • Type cat ~/graylog.creds to get admin password that you use to log in AFTER the Initial Setup
RAM: 8GB
HDD: 30GB
Default Interface: IP:9000
Whatch out when you upgrade proxmox to kernel 7. The graylog server cant cope and the whole graylog container is useless. I use graylog on proxmox and have had to pin the proxmox node kernels to 6.something to keep graylog lxc working.
