Glance is a self-hosted dashboard that puts all your feeds in one place.
To create a new Proxmox VE Glance LXC, run the command below in the Proxmox VE Shell.
To Update Glance, run the command below (or type update) in the LXC Console.
bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/ct/glance.sh)"
Config file is located in: /opt/glance/glance.yml
HDD: 2GB
Default Interface:IP:8080
