Fluid-Calendar is a open-source intelligent calendar that adapts to your workflow. Experience seamless task scheduling powered by AI, designed to make your time management effortless.
To create a new Proxmox VE Fluid-Calendar LXC, run the command below in the Proxmox VE Shell.
To Update Fluid-Calendar, run the command below (or type update) in the LXC Console.
bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/ct/fluid-calendar.sh)"
- Creds:
cat ~/fluid-calendar.creds - Documentation
CPU: 3vCPU
HDD: 7GB
