Signing documents digitally should be fast and easy and should be the best practice for every document signed worldwide. This is technically quite easy today, but it also introduces a new party to every signature: The signing tool providers. While this is not a problem in itself, it should make us think about how we want these providers of trust to work. Documenso aims to be the world’s most trusted document-signing tool. This trust is built by empowering you to self-host Documenso and review how it works under the hood.
To create a new Proxmox VE Documenso LXC, run the command below in the Proxmox VE Shell.
To Update Documenso, run the command below (or type update) in the LXC Console.
bash -c "$(curl -fsSL https://raw.githubusercontent.com/community-scripts/ProxmoxVE/main/ct/documenso.sh)"
Location of config file /opt/documenso/.env
You can use the following credentials to login to the Documenso ct.
helper-scripts@local.com - Password:
helper-scripts
CPU: 4vCPU
RAM: 6GB
HDD: 10GB
