Dashy is a solution that helps you organize your self-hosted services by centralizing access to them through a single interface.
To create a new Proxmox VE Dashy LXC, run the command below in the Proxmox VE Shell.
To Update Dashy, run the command below (or type update) in the LXC Console.
bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/ct/dashy.sh)"
Default Settings: 2GB RAM - 6GB Storage - 2vCPU
Dashy Interface: IP:4000
Once you’ve configured everything according to your preferences in interactive mode and saved the changes to the disk, go into update configuration and rebuild application.
