Cross-seed is an app designed to help you download torrents that you can cross seed based on your existing torrents. It is designed to match conservatively to minimize manual intervention.
To create a new Proxmox VE cross-seed LXC, run the command below in the Proxmox VE Shell.
To Update cross-seed, run the command below (or type update) in the LXC Console.
bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/ct/cross-seed.sh)"
- After the installation cross-seed will fail to start with an empty configuration. To fix this, edit
~/.cross-seed/config.jsto properly configure cross-seed, then restart by runningsystemctl restart cross-seed.
HDD: 2GB
Default Interface: IP:2468
