Crafty Controller Proxmox LXC script
Crafty Controller is a free and open-source Minecraft launcher and manager that allows users to start and administer Minecraft servers from a user-friendly interface. The interface is run as a self-hosted web server that is accessible to devices on the local network by default and can be port forwarded to provide external access outside of your local network. Crafty is designed to be easy to install and use, requiring only a bit of technical knowledge and a desire to learn to get started. Crafty Controller is still actively being developed by Arcadia Technology and we are continually making major improvements to the software. Crafty Controller is a feature rich panel that allows you to create and run servers, manage players, run commands, change server settings, view and edit server files, and make backups. With the help of Crafty Controller managing a large number of Minecraft servers on separate versions is easy and intuitive to do.
To create a new Proxmox VE Crafty Controller LXC, run the command below in the Proxmox VE Shell.
To Update Crafty Controller, run the command below (or type update) in the LXC Console.
bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/ct/crafty-controller.sh)"
Show password: cat ~/crafty-controller.creds
HDD: 16GB
Default Interface: IP:8443
Hi! I need some help. I’m trying to run a crafty controller on my proxmox homelab server, and the installation goes fine. The script creates the container, install everything and runs fine, until I restart proxmox. When I connect back to the container, not even docker is installed and I don’t know how to make the container persistent.
Thank you!
