Cloudreve Proxmox LXC script
Cloudreve is an open-source, community-driven cloud storage system that provides file sharing, synchronization, and management features. It supports a wide range of storage backends and integrates with various notification and logging platforms.
To create a new Proxmox VE Cloudreve LXC, run the command below in the Proxmox VE Shell.
To Update Cloudreve, run the command below (or type update) in the LXC Console.
bash -c "$(curl -fsSL https://raw.githubusercontent.com/community-scripts/ProxmoxVE/main/ct/cloudreve.sh)"
After Installation: Register your user → Login → Dashboard → Accept Primary URL.
Location of config file
/opt/cloudreve/data/conf.ini
  • CPU: 1vCPU
  • RAM: 1GB
  • HDD: 10GB
  • Default Interface: IP:5212
