Cloudflared is a command-line tool that allows you to securely access resources on the Cloudflare network, such as websites and APIs, from your local computer. It works by creating a secure tunnel between your computer and the Cloudflare network, allowing you to access resources as if they were on your local network.
To create a new Proxmox VE Cloudflared LXC, run the command below in the Proxmox VE Shell.
bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/ct/cloudflared.sh)"
