Bitmagnet is a self-hosted BitTorrent indexer, DHT crawler, content classifier and torrent search engine with web UI, GraphQL API and Servarr stack integration.
To create a new Proxmox VE Bitmagnet LXC, run the command below in the Proxmox VE Shell.
To Update Bitmagnet, run the command below (or type update) in the LXC Console.
bash -c "$(curl -fsSL https://raw.githubusercontent.com/community-scripts/ProxmoxVE/main/ct/bitmagnet.sh)"
As an alternative option, you can use Alpine Linux and the Bitmagnet package to create a Bitmagnet LXC container with faster creation time and minimal system resource usage. You are also obliged to adhere to updates provided by the package maintainer.
To create a new Proxmox VE Alpine-Bitmagnet LXC, run the command below in the Proxmox VE Shell.
bash -c "$(curl -fsSL https://raw.githubusercontent.com/community-scripts/ProxmoxVE/main/ct/alpine-bitmagnet.sh)"
During installation you will be asked to enter your TMDB API key, if you want to use it. Make sure you have it ready.
Location of config file: /opt/bitmagnet/config.yml or /opt/bitmagnet/.env
Default Interface: IP:3333
Alpine settings
HDD: 3GB
