Barcode Buddy for Grocy is an extension for Grocy, allowing to pass barcodes to Grocy. It supports barcodes for products and chores. If you own a physical barcode scanner, it can be integrated, so that all barcodes scanned are automatically pushed to BarcodeBuddy/Grocy.
To create a new Proxmox VE Barcode Buddy LXC, run the command below in the Proxmox VE Shell.
To Update Barcode Buddy, run the command below (or type update) in the LXC Console.
bash -c "$(wget -qLO - https://github.com/community-scripts/ProxmoxVE/raw/main/ct/barcode-buddy.sh)"
After install enable the option “Use Redis cache” on the settings page.
HDD: 3GB
Default Interface: IP:80
