Bar-Assistant Proxmox LXC script
Bar Assistant is all-in-one solution for managing your home bar. Compared to other recipe management software that usually tries to be more for general use, Bar Assistant is made specifically for managing cocktail recipes. This means that there are a lot of cocktail-oriented features, like ingredient substitutes, first-class ingredients, ABV calculations, unit switching and more..
To create a new Proxmox VE Bar-Assistant LXC, run the command below in the Proxmox VE Shell.
To Update Bar-Assistant, run the command below (or type update) in the LXC Console.
bash -c "$(curl -fsSL https://raw.githubusercontent.com/community-scripts/ProxmoxVE/main/ct/bar-assistant.sh)"
Location of config file
/opt/bar-assistant
  • CPU: 2vCPU
  • RAM: 2GB
  • HDD: 4GB
  • Default Interface: IP:80
